Hi there,
I read that the Avant non-NG uses a Samsung LTA550FJ01 LCD panel. But which ones does the NG use?
And if you replace a panel, is it a simple matter of plugging in a new one, or does there some sort of programming need to happen (ignoring the fact that it might need some calibration).
Thanks for your help.
Avant NG LCD Panel
Hi
Avant 55NG use LTA550FJ04
Programming thru servicetool for calibration
needed for correct picture
Thank you for the info. Sadly I couldn’t find any other TV which also uses this exact panel.
The Philips 55PUS8809 seems to have a LTA550FJ01.
Maybe they are intercompatible ?
