I have a Bang & Olufsen MX6000 that has a fault that the image randomly jumps. It's an early one made for the Italian market Type: 35/04 MTI SW1.2 Using an ESR meter I tested all electrolytic capacitors on the power supply and deflection board and I found five bad ones. They where all the same brand and rating 470uf 16V. I thought that replacing the bad caps would of sorted the problem, but no difference. Here is a video of the fault: https://youtu.be/hWppZPKIPA8 If anyone knows what the problem might be any help would be appreciated. Cheers, Martin.
