Beo4, BV9 and Beocenter 2
Hi
Need help with BV9, Beocenter 2 and Beo4.
Been trying to change all the possible OPT possibilities but
just can't get it right:) Beocenter is connected with masterlink and scart to tv.
What might be the right option to this setup?
Step by step for dummies:))
/api/files/847821a98c17403ea05567c66ce61c15
Page 10
Yep, have the same side open, but still don't get it working:D
Now I picture and sound on tv, but still can't use beo4 to controll DVD..........
Is it possible that there is some other solution? If I set options like in that pic
Beocenter does not accept any comands - no sound in cd and nothing from dvd.
Do I have to have ir in socket box ctrl?
Make sure you have a fully wired scart cable, Instructions are send through scart.
Have check still that.
Thanks for the advice.
The reason for problems was that scart cable. I have a box full of those and the fifth was a proper one. They seemed to be fully connected but still there are some difference.....or just broken:)
And when you live long enough..............:)
Syndicat des Constructeurs d'Appareils Radiorécepteurs et Téléviseurs
^ Good old SCART leads!! I keep a large box of them just in case! (also for temporary connection of DVD1 and/or V8000 to amuse my grandson ?)
