Hi Beoworld, what's the best/cheapest way to get a VESA adapter to put my Beovision 10-40 on my rolling TV stand?
my stand supports VESA mounts:
200 x 200 mm,
300 x 300 mm,
400 x 200 mm,
400 x 400 mm,
600 x 400 mm
this is the one I got LogiLink Stand TV (Sol, 70 ", 40 kg) https://www.digitec.ch/fr/s1/product/logilink-stand-tv-70-40-kg-pied-tv-12546326 hoping it'd be ok for a Beovision 10-40 even though chatgpt tells me the Beovision might be 2-5kg heavier than my rolling stand's rated weight limit..
I am trying to figure out what the "B&O Wall Bracket Beovision 10-40" official from B&O can do, do you know if it tilts? And I guess this wall mount does not convert it to VESA mount, right?
Beovision 10-40 adapter for VESA mount?
