Beovision 6 stand reduce height
Does anyone know if it is possible to reduce the height of a Beovision 6 stand? Is it at all possible?
I guess it would involve some metal cutting in the bottom of the pole, but what about the attachment of the pole to the rotating mechanism?
Thanks in advance
The metal of the pole is a constant cross section and if I recall correctly there are four screws that go into the pole from the base vertically from below. With a very neat (accurate) cut this should be very achievable. I assume that you need somewhere between table stand and floor stand height?
EDIT2: I think (not 100% sure) that the screws are self-tappers hence no need to make a new internal thread in the pole.
EDIT: Zoom in on the one that is missing its pole and you will see the screw holes:
Login to view image
Thanks for that.
I am thinking about a 10-20cm reduction to make it usable under an angled roof.
Great if the screw situation is not a problem. I will try to disassemble and look into it
Ok so I got it disassembled. Pretty easy when using your instructions.
But I can see that even though the cross section is the same in the entire lenght of the pole the threaded holes is only about an inch deep and stops where a reces is cut into the cross section
Login to view image
So in order to cut down the lenght of it new holes will have to be drilled and threaded at the place where it is cut.
This would require some drilling equipment that I do not have, so I guess this will not be the way to go.
The reason for investegating this option was that I have the stand and might as well use it if possible. However I might look into other placement options, and/or maybe the smaller BC6-23 as an option
That's a shame. But a good exercise in Beovision stand disassembly!
How about trying to find a BV6-26 table stand, Type Number 4092? That's significantly shorter.
Have a look on the back of the BV26 Service Manual. This has diagrams of all the stand options with Type numbers. However, I can’t recall ever seeing one in person!
EDIT: I am pretty sure that the same table stand is used for the BV7-32. It has attachment holes for the Beolab bracket, although I think these are covered when the BV6-26 is mounted.
