Hi, we’ve recently picked up a second hand Beovision 7 Mk4.
I’ve managed to connect a firestick to HDMI A and can pick it up using the VMem on the remote control.
I can’t for the life of me work out how to also connect a BT You view box too. It is in HDMI C on AV2 but I can’t select it on the remote control and there doesn’t seem to be an obvious way to do it. It’s currently a V Aux selection on connections.
I’ve gone through the instructions to register the device (unknown STB) but then how do I actually connect to watch? Many thanks
Beovision 7 - contacting STB and Firestick
If your problem is, that you can not find a button on the remote to do this (V-AUX), you can find this button by adding it to the List.
This way you just push List multiple times - or just one, if it can be moved to the first place there.
Here is how to add items to the List on the Beo4:
https://youtu.be/Zcitl1pKOjI
Thank you so much - that has cracked it!
