Beovision 7-32 HD connections
Message
I have a 2007 Beovision 7-32 HD with Scart sockets leading to a dish based Humax 500 Mb recorder box. This box is failing but replacing with a new Freesat HDMI recorder is causing problems because there is no HDMI socket on the B&O and an HDMI converter to Scart doesn't work - I've already tried it.
I'm told that it's possible to use the DVI socket via a HDMI-DVI cable but with phono-stereo jacks too, presumably for sound? Would the phonos connect to the sound stereo jack or Optical socket on the Freesat box?
I have connected the audio to the chinch connections at the top right.
Login to view image
