Hi, to start my beovision 7-55 do I need to cut the main-power about 5 times before the tv will start.
(The standby lamp seems weak at the first attempts to start tv, also the DTV text appears weak at first, after some time 3 to 7 times power on and off the standby led gets brighter and the text DTV also whereafter the TV starts-up.
Thank you any advice is most welcome
Regards Nicolaas
Beovision 7-55 Start problem
most probebly new powersupply needed, maybe some capacitors failing but have not look into it
