Beovision 7 floor stand - quick question
I have not been able to figure this out so in case anyone knows - would the motorised floor stand item 1404111 for a BV7-40 also work with a BV7-32? Is the bracket the same size?
Old enough to have gazed at classic B&O HiFi in Plumbs shop windows in the 80s...
No.  The 7-40 bracket (the bit that actually supports the TV) is much wider - you can see that it has levers going into each of the two support poles. The BV6-26 brackets will support the BV7-32 (but won't necessarily have the bracket mount below the TV for a Beolab).
Yes I did think that when I looked at the photograph, but wanted to be sure.  Thanks for confirming.
