Good afternoon, this is my first posting on the Beoworld forum. Can anyone help me with the problem I am having on my TV screen ? My B&O Avant 75 is from the first generation and is from 3/2016.serial number: 26206147. I have vertical lines of +/- 10 cm on my screen and especially in dark pictures they are visible. It seems like the colors are not synchronised. Is the LCD screen broken ? burned ? worn out ? Thank You for Your feedback
Beovision Avant 75 screen issue
Seeems like the video engine problem to me, had it several time when i had the avant.
1200 fix
Thank You for your help. 1200€ of £?
B&O had many troubles with the video engine, originally the price was £1200 fitted, then the price of the exchange board dropped to £750 plus fitting , as so many were going faulty, they seem to last for about 4 years, although my replacement lasted 14 months.
Maybe its more of a problem with the 55 as the chassis is more compact and greater heat issues, which seem to cause the problem.
