Beovision Horizon
Yes I already had such a case.
I have just taken my Beovision out of storage but the beoremote one is lost, also I have just the green light with no picture ?
two questions can I use any BO remote and should I not have some sort of picture when plugged in
thanks in advance
col
To my knowledge you can only use the Beoremote One with the Horizon.
Not sure why you only get green light. I assume it would go into standby when you plug it to the mains.
hi
much appreciated, the green light only
stays on for one minute and then goes blank
ill have to find another beoremote one
kind regards
col
I may be wrong but is it possible to control it with the Bang and Olufsen app (which replaced the Beoremote app)? The TV would have to be connected to be connected to the same network as the phone, so this will only work if the TV is able to connect based on its previous settings. It could be worth connecting the TV directly to your router with a network cable, and then see if the B&O app can find and control it.
It's just a thought - I don't have such a modern B&O TV ?
Be sure to get the Beoremote One/BT.
The BV Horizon only works with bluetooth!
Tip!
If you have the Bang & Olufsen app and the tv is online/on the same network as the device with the app, you can control the Horizon that way.
Well….Guy was faster than I ?
Thanks all
for your help the BOApp worked ,
but only to show me a crack LED Must of happened in storage!!
is it worth getting a new screen?
much appreciated
col
Hi All
another question for the experts, what make of screen has the Beovision horizon 40 have, I’m going to attempt replacement my self ?
kind regards
col
I would hazard a guess at Samsung, but your best bet is to take the TV apart and look for a label!
