BoeVision Avant 55 - green horizontal line
Hi All, Re. BoeVision Avant 55 - green horizontal line A thin horizontal line has appeared on my screen approx. 150mm from the top of the screen. Very annoying and looks awful. Any advise would be appreciated as to repair or worse etc... Best regards, Andy
Sorry to tell you this…… ….but assuming you have the first gen Avant, this seems to be the first sign of a failing video engine. Do you see that with any source on the Avant? It probably will get worse! The only cure then, will be a new video engine board - please contact your/a dealer for further advice. MM
Thank you MM, Unfortunately I do still see it with other sources (laptop connected through HDMI cable). Appreciate the advise. It's disappointing as I would expect better longevity!
