Short version: Today I have a BV 10-46 with a fully functional DVB-HD module.
Long version:
Loosened the six screws and lifted off the front frame as described in the service manual.
Login to view image
The marked panel had to come off. 13 T10 screws.
Login to view image
The DVB-HD module. Two connectors, J7 and J18. I did not remember where they should be connected. I later discovered that a short RJ45 connection from the top of the card to the bottom connection panel had gone missing. Solved by inserting a short ethernet patch cable. It will be available should the need arise without having to dismantling the TV.
Login to view image
Connector J 7 in the middle of the picture.
The DVB module goes into the open space to the left of connector J7. When the picture was taken, I had yet to remove the blind lid in the bottom.
Login to view image
Marked position for J 18.
When everything was connected and re-assembled, I launched the service menu -- DVB service -- and changed DVB connected to YES.
After a restart of the TV, all DVB-services I expected are now available to me.
Sverre
