Change to RCA mode from remote.
Dear Forum experts!
I have finally been able to connect my Apple TV and look forward to be able to use the beautiful Beovision 6 for many more years to come.
The problem I have now is that I cannot switch to the RCA mode without pulling the power cord to the RCA adapter. I am sure there is a way to get to the RCA mode from the remote but I do not know how. Would anyone have an idea?
The Apple TV is connected over a HDMI to RCA converter and I am looking for an easy way to switch similar to the traditional source button on many modern TVs where RCA is an option.
Looking forward to hear your comments.
Karl
Which terminals are you using on the TV? If it's the ones behind the little flap top left then you can activate by pressing CAMERA on the Beo4 remote.
You can add CAMERA to the Beo4's LIST button by following this procedure:
- Press Power (Red Dot) and LIST together, the display should read ADD?
- Press GO.
- Press LIST until the display shows CAMERA, then GO.
You should now be able to find CAMERA by pressing LIST repeatedly until it shows in the display. Then simply press GO to select the input.
Thanks Guy!
That works perfect!
My remote says CAMCORD but except for that it works just like you said!
Thanks a million!
Carlos
Great result - thanks for letting us know that it worked, and enjoy your TV! ?
