Horizon vs. Countour
Title says it. Horizon is discontinued and replaced by Contour. 2nd hand Horizon are around and not crazily expensive.
Contour has OLED (i.e., clearly a better screen). I find the Horizon design more appealing.
Both don't have the "B&O curtain", right?
I know people dislike the old Android OS on the Horizon, but I would likely anyways use an Apple TV. Do both Horizon and Contour have a place to slot in an ATV?
How is the webos on the Horizon/Eclipse? Is it modded to give me a B&O UI or will I see LG logo and ads?
Beolink works with both?
I dont think either have a slot / space for an Apple TV.
Unless you're wall mounting though, it should be pretty easy to attach one to the back of either.
When it comes to the Horizon and its OS - the Android OS is one thing (early version, not good), but the general TV OS (there is a B&O non Android part for settings etc)wasnt stable. That may have become better (owners may help out with responses), but the Android OS won't get any updates really.
The Horizon OS has s (&O) section for settings / setup etc, but mainly what you see is Android OS (some dont mind it, I found it not great). With the Contour, you will see pretty much the LG webOS, which is such better than the Android OS.
There is no B&O based OS anymore on their Beovisions.
Personally I'd steer well clear of the Horizon - the LCD screen in it is god awful. The Horizon only really has a slightly nicer design (than the Contour) in its favour. Unfortunately, its also only a standalone unit (no additional speakers) and is way too expensive for what it is.
The Contour is also a stand-alone unit without additional speakers?
If I am greeted by an LG logo when starting the Contour, this is another positive point for the Horizon.
To summarize for my use case:
Horizon: Less than half the price, nicer design, no LG logo or ads
Contour: Much better picture quality (OLED)
Horizon:
- I expect an ATV will fit behind the back covers (never tried though),
- Android OS isn't the best. It has sometimes strange behaviours. But ours is still one which is often used,
- As described the Horizon settings menu's are B&o like and sure WebOS is better then Android TV,
- the Horizon is NOT a stand-alone tv. Additional PL speakers can be fitted (it has a similar Sound setup as the BV11).
- AND it still has curtains
Thanks. Leaning more and more towards a used Horizon though now.
You are right. Horizon even has a sound module and WISA.
One question: Is it possible to set it to start always with Apple TV? If so, do the curtains still show and can I still use beolink and googlelink/chromecast?
Also, have you tried to connect bluetooth controllers (gamepads) to the Horizon?
Hi Millemissen,
When you quote someone's post you may want to unclic the "Block quote" button in the toolbar after a carriage return to have your message displayed as a plain message.
Login to view image
Thanks. Good to see @Millemissen on the "new" forum. I regularly frequented the old forum. The UI of the new one still need to grow a bit on me, but great to see the long-standing experts here.
Seems I will go with the Horizon.
Yes, my question is about connecting gamepad (Xbox, PS, etc.) directly to the Horizon. I can of course do to the Apple TV, but I am wondering whether I can also do so directly to the Horizon in case the Android OS is not as bad for me as many people say. Then I don't need the Apple TV. And given it had some B&O skinning, maybe I prefer so.
I'd put it differently when. it comes to picture.
The ~Contour with the OLED has a superb picture quality.
The Horizon has a god awful LCD panel - less of an issue with sports / news I guess, but many dramas and movies these days have dark scenes, and those are pretty close to unwatchable on the LCD which uses global dimming. I lived with one of these (in the BV14, same LCD panel ) until enough was enough, and it had to go back.
In the end, one does get a TV to watch things properly, and ideally very well.
Login to view imageI’m super happy with my Contour. Picture, sound, looks and user experience is 10/10.
I only use Apple TV, its hidden in a «hole» on the backside of the Stage. That gives me a clean look placed on the wall.
I’m not a tv/movie guy, I use much more time with music, and that is a separate setup (BL18/19) that I don’t want a between.
If I only had one livingroom, then I would have needed a BeoVision with connections for speaker, but for my case, this tv is all I ned….for now:)
