How to integrate BS Essence into BV14-55
Can anyone help me to successfully integrate the Beosound Essece Mk2 into my Beovision 14-55. Which setting do i need to make?
With thanks!
Don't know what settings are needed on the Essence but on the BV14:
Settings => Product Integration => Link to other products > <select your Essence>
After that: your Essence should be be visible in Settings => Sources list.
Karel.
You will also have to go (deep) into the settings of the Essence.
In the app navigate untill you reach the webinterface of the product.
’Configure’ and then ‘Settings’
There you will see ‘Beolink’ -> ‘Connect to other products’?
This is where you choose your BV.
Login to view image
Don’t forget - both products must be on the same home network!
MM, in the picture you've attached on Essence settings, there is a setting called "Lydsynkronisering". Do you know if the setting is for removing potential audio delays with other B&O products?
It is - but not relevant in your case.
See:
https://support.bang-olufsen.com/hc/en-us/articles/360041419912-How-do-I-make-settings-for-Line-in-sources-in-the-Bang-Olufsen-app-
MM, thanks for your answer and the link. I assume then that the function isn’t compatible with Mozart based products!
