Making HDMI the standard input on Beovision 8-32 with an old Beo4 remote
Hi, I’ve tried researching a whole lot to solve this problem, but I’ve had no luck so far, hope someone on this forum can help. I bought a Beovision 8-32 used, and set it up with an Apple TV via HDMI. I put it on AV1 in the menu as a DVD player. The problem is that my old Beo4 remote does not have a DVD button, but I’ve programmed it so I have CDV button under the list which makes the TV switch over to the correct input. This works okay, but is a bit annoying. In everyday use, my Beovision TV defaults to the TV signal input when turned on, and has to be switched over manually to the HDMI input via the DVD/CDV «button». What I’m hoping to achieve, is the possibility of the TV automatically displaying the HDMI input as a default when turned on. This would be especially convenient as the Apple TV remote is able to switch the TV set on and control the volume, which would minimize the need to fidget with the Beo4 to display the intended content. I hope someone knows a possible solution to achieve this. Alternatively, if HDMI as the default displayed input is not possible, I wonder if anyone knows a more convenient button on the old Beo4 remote that can be programmed to one of the HDMI input modes on the Beovision 8-32. A single physical button would be a whole lot more convenient than navigating the LIST button each time. I’m loving the TV set so far, and hope someone has the knowledge to help me make the experience even better. Thanks in advance.
Hello and welcome to the Beoworld forums. First of try to take a look in this thread I have made about the Apple remote and B&O TV's
  • Control both BV8 and Apple TV with BEO4
  • Control both BV8 and Apple TV with Apple Remote
  • For option number 1 you will have to use the built in PUC system in the BV8 which will give you the ability to relay IR commands from the BV8 to the Apple TV with a little IR sender that has to be placed on the front of the Apple TV. Your BV8 might not have the PUC code for an Apple TV, but this can be updated by a B&O dealer. Alternativly you can use any other PUC code and let the Apple TV learn theses commands. For option number 2 the HDMI input has to be assigned for the "TV" command as this is the only one the Apple remote is sending to turn on a B&O TV. I am not sure if this is possible on the BV8-32 and might also depend on software version. But in short if it works you will have to turn of both the analog and digital TV tuner in the service menu to free up the TV command. Then you should be able to assign the TV command to the HDMI input. Hope this input is usefull, and please writhe back if you need more info on some of the options I have described, then I or an other forum member might be able to help you get it up and running.
