Making own choice channel lists
I am wanting to make a list of my viewed channels, I have followed the BV10-40 Mk1 manual which indicated there should be onscreen instruction.
There are none, I have a question lodged with customer care!
How do I achieve this or should I just create a Favourite list?
Thanks in advance
Tony
I also wanted to amend the channel lists on my BV10-32, but couldn't make changes using the method in the user manual - it just didn't work! (I wanted to move the UK Freeview HD channels from 101, 102, 103 etc to replace the SD channels 1, 2, 3 etc)
Although I didn't try, I think the solution could be to make a Favourite List, but I couldn't be bothered to move across all the other channels that I view.
It will be interesting to hear the response from B&O.
I have now got back to this small problem.
I have been 'fiddling' about with the Favourites list, and have had some success!
Probably because I do not use cards , just use 'Free to Air' satellite channels.
Consequently the saved/moved channels are numbered from 1 in the listings, it's a bit 'b*ll aching' but I am happy with this as my other B&O tv's do not have the relevant pcb's fitted.
So for my satellite viewing I use satellite boxes which have the channels numbered from 1 onwards!
It is a pain when the channels are rearranged on the satellite though!
Still no response from Customer Care!
