So far, all good, Audio is as it should be(amazing) and DVD player works, only thing I have is a blurry top left corner on image most noticeable with the menu, will run a few more tests but assume some re capping and likely the tube socket, however I have not been able to find any parts out there, if anyone could point me in the right direction, that would be fantastic. cheer Regards Brad<!--more-->
<!--more--> Login to view image <!--more-->New Project Beovision Avant 32DVD
Sparky
Hi again,
I have 2 Avant 32s and a BV3-32, my friend also has 2 Avant 32s.
We absolutely love them and another video I need to do is re-capping and the full shabang or re-calibrating one, they can be quite involved. Where are you actually based? reach out to me directly, I'd like to have a proper chat with you about all the shared interests ha.
Thanks,
Cheers David
Way down New Zealand Thames, electrician and all things tech, security etc. by day and this as. a. hobby.
bradadamselec@gmail.com
Sparky
I've emailed you so check your junkmail!
Hello,
I own a Avant 32 since new but one day I've messed with geometry settings and now the image is weird.
So I'm here trying to get your help with just a photo of your geometry settings or just the values.
I've been trying to find default geometry settings in Google but without luck.
Hope you can help me.
I've attached a picture what it looks like.
Here's how you can access to it:
To access the "Service Menu" do the following:-
Press MENU
On the menu screen use up/down arrows to highlight SETUP then press GO
Now press 0 0 then GO and you are in the service menu
Choose Monitor
Now Geometry Adjustment.
If possible please post all the numbers here
Sorry for bothering.
Thanks in advance.
