I have just set up a Beovision MX7000 that I just got and when I press MENU only Program List and Setup comes up, no Sound or Picture.
Is there a way to access the sound and picture settings on this device? I am using a Beo4 remote.
The user manual says sound and picture should come up in the menu but here it doesn't. I wonder if it's because this TV is Software 1.1 and not higher?
No sound or picture settings for MX7000 sw1?
Long time since I had a MX TV...
But I believe the menu is different depending on source.
Try select TV on Beo4 - not V.TAPE, DVD or other sources assigned to an AV input.
What can you adjust in the SETUP sub-menu ?
You could have a look in the service menu.
But be careful what you change ...
I have the same problem with the menu, can't figure out how to fix it. MX7000, sw 2.0.
What remote do you have?
If you have one of the ugly ones with a display then you need to enter V.SETUP on the remote. You can achieve this by pressing LIST several times until it shows up, then GO, and then LIST again until PICTURE or SOUND is displayed. Remember to press LIST again until you find STORE when done to store your settings.
If V.SETUP can't be found on your remote, then you need to add that option to the list first. You do this by holding down Power, then pressing LIST, then ADD.
