Hello,
I am trying to remove the upper front panel of a Bang & Olufsen MX8000, the section at the top front where the LED indicator is located on the right.
I cannot find any screws holding this part in place from above. It might be secured with clips, but I am not certain. When I carefully pull the panel slightly forward, nothing seems to come loose.
Before applying more pressure and potentially damaging aged plastic parts, I would like to understand the correct removal method.
Is the rear cover required to be taken off first?<br data-start="876" data-end="879" />Are there hidden locking tabs that must be released from inside?
If anyone has experience with this specific model, I would greatly appreciate your advice.
Thank you.
Samy
