Stream audio to Beovision without turning on screen
I have a BV Horizon. I have a few questions how to stream audio to it:
  • I can use "join" in the B&O APP to play audiostreams. However, this turns on the TV. I'd prefer that it only plays audio with the screeen staying off. Is this possible?
  • I am wondering whether I can define a speaker group that I can play to when hitting "join" rather than the BV Horizon speakers.
Thanks for any help!
I don't know about the Horizon, but we have an Eclipse and the screen activity, speaker group and whether the TV rotates out from the wall on its bracket are all configurable in the setup menus for the relevant input. I would be surprised if you couldn't do the same on the Horizon.
Thanks. This still keeps the screen on and displays a blackscreen? I thought there would be a way not to turn on the screen, but connect directly with the audio module?
Pulling up an old thread again. I am still trying to solve for the holy grail: Playing audio to my BV Horizon without turning on the screen and without using the Beoremote. I can initiate stream to my A9 (airplay or B&O Radio). I then want to extend the stream to my BV Horizon via the B&O app. However, this only seems to work when the BV is already turned on? Does extending via the app require the TV to be turned on? If so, any other ideas how to get what I want to achieve? Maybe with an Essence? Or a Halo?
Have a look at your remote control. I assume it is a BR1? I assume the A9 and BV are not connected in any way (cable or wifi or BT)? Im not sure how the BeoApp plays into this as it is essentially a protocol control link in itself (not in a good way) I think you can pull up products on the BR1 as a top-level and get Beovision and Beosound added. List >> Settings >> Advanced >> Products >> Show >> tick Beovision and Beosound The default will always be the "System name" which will likely be the Beovision. Now, press List and thumb to the "System name" List >> System Name >> Beovision or Beosound >> select Beosound. List will now have all the major controls for the Beosound and will be out of Beovision control until you reverse the over-riding control. (Caveat; This may all be wrong! I cant test myself but do recollect a long time ago trying to get the BR1 to work to the buttons rather than LIST with a NG Avant and BS5) Good luck!
I forgot to mention that this will only give you isolated Beosound sound at the Beosound I dont think it will give you piped sound to the Beovision. You can use Join but I think you will switch the panel on. You may get lucky and see the P.Mute button come up in the Beosound LIST once joined?
Thanks. My BV and my A9 are both connected to the same home wifi. I also have an ATV connected via HDMI to the BV (also connected to the same wifi). Ideally, I don't want to touch the BR One to stream music. Just my iphone to play music (Spotify) or extend audio over NL. Both BV and A9 show up in the B&O app. All works smoothly as long as the BV is turned on. What I am trying to solve is to stream audio to the BV. Either directly via NL or using AP via the ATV. Or through another device (e.g., CC). But in any case, I would like to stream the audio to the BV without using the BROne to turn it on. Can audio mode be activated via line-in sense? Via HDMI sense? or via the B&O app via "join"? Or other ideas?
I think if you can get what I have said above to work - with either join or join source, then Mybuttons can come to the rescue. From there, you can undo the changes to BR1 and I would expect the phoneApp to respond with the macro? Best I can think of just now.
