Beovox 3702 Crossover Capacitor Values
Hello. Hoping for some help with a pair of 3702s I've acquired. First job is replacing crossover caps and re-foaming the woofer - unfortunately the print on the woofer capacitor is not readable - does anyone have the values? Many thanks.
Depends on the type of Beovox 3702. Kits are readily available: https://www.beoparts-shop.com/?s=3702&post_type=product Martin
Regardless whether you ended up buying the kit or not, I thought I'd post the values in my 3702 6244's.  I'm also replacing the caps in mine so I took pictures and recorded the values. The values are 3.3uF, 8uF, 37uF, and 50uF; all 25V. If anyone happens to know exactly which caps are in the kit, that would be great to know since the product page doesn't say. Steve (I originally thought the 3.3uF was a 2.0uF, that's why there's a picture called 2.2uF Cap)
