Sometimes when buying used B&O you get something extra.
A couple of months ago I was looking for the glasplate for my BM4500 and ended up getting it by taking a non working BM3500, a set of RL45.2 and 5 BL1000 remotes for a very reasonable price.
One of the RL45.2 has a broken strap so looking out for that I found that the cheapest route was to buy a set of RL45 to get an extra strap.
My space for B&O stuff is limited though, so I am no keeping two sets of near identical speakers.
The question is which should I keep.
The fabric on both sets is of course not new anymore, but I would say in fine enough condition for my use.
There does not seem to be any foam rot on the speaker units in any of them.
Login to view image
The Bass ports in the RL45 also seems ok (they were renovated according to the seller)
Login to view image
Are there any technical and/or sound wise reason for keeping the on type or the other?
Any insights are welcome
Thanks in advance
