CX50 foam or rubber
Replacing surrounds on CX50 (or CX100) you can many places choose between foam or rubber.
Was the CX50 from factory produced with foam surrounds? and would the characteristics of the speaker change notably by repair with rubber surrounds?
Some claim that using rubber surrounds last longer but what about the sound quality?
What you you choose?
/Pindsen
The originals were foam type surrounds.
How noticeable the difference is will be purely dependent on the listener.
If you are trying to keep things to the original design then stick with foam surrounds.
It would be interesting if you were to do one with foam surrounds and the other with rubber, then see if you can tell a difference.
Those are pretty easy drivers to replace surrounds on so it wouldn't be difficult to try.
Plus, those being small drivers, the surrounds don't cost much.
If you do the test be your and post about it here.
-sonavor
The originals were foam, therefore I'd replace them with foam.
Changing to rubber will alter the parameters of the drivers and make them sound different. Whether this is an improvement or not is purely subjective.
Specifically changing from foam to rubber will alter the low frequency resonance changing the bass response.
I will try to compare and return with my perspective as I have both.
/Pindsen
Foam, where foam was used originally.
Repalcing with rubber changes the T/S parameters drastically.
If you only had the T/S to compare, you would never suspect it to be the same driver.
What does T/S mean?
/Pindsen
I changed my CX30's and CX100's to butyl surrounds and doped the cones. It greatly improved the midrange, yet slightly lowered SPL of the lower bass frequencies. Was a win/win running them with a subwoofer.
Login to view image
Login to view image
Login to view image
