Hi there, I am not very experienced with the Beogram 5005 record player and I need some help wth the following problem. The player works fine it plays records 33 and 45 ans starts and stops fine the only strange problem is that when the arm carriage returns to it stop place fully to the right side the motor does not stop and the carriage vibrates for a few seconds. I cleaned and lubricated the guides and the 2 belts are new but this problem remains. The servive manual is not very clear of explaining all  the switches. So in short this is the problem. When I play a record it starts and plays correctly at the end it stops and the arm carriage goes to its base position to the right but does not stop when it's there it vibrates and clicks a few seconds. Is there anyway to correct or adjust this. Thanks for your suggestions Fred
Fred Dijksman
