Almando Multiply Decoder MKIII
Hello everybody. At the moment I‘m not happy with my Beosystem 3. We all know that the Beolab 2 won‘t be turned on in case you have Beolab 5 attached to the BS3. I want to use my Beolab 2 to compensate some room modes. Does somebody is using the Almando and can tell me if it allows the BL2 to play even when the BL5 are on? I still don’t get why B&O thought this was a great idea back then..   Btw: Yes I know that you can plug it in and tell the BS3 that it is not a Subwoofer. But that way you still can’t use it in Speaker Mode 2.
hello. Yes you can use BL2 with BL5 when connected to Almando. You do all your settings in the almando app.
