B&O Radio
Hi, had no one else this problem? b&o radio on bs level can’t play bbc radio 6 music   With other bbc stations there is no problem. Communication with bo support is very complicated and I’m very frustrated. Greetings
Not that I think this will help/solve your problem… I can’t play anything B&O Radio here, but BBC6 plays fine from the built-in TuneIn (supposed this is what you are looking for). And BB6 shows up in the B&O Radio part, even if my M3 can’t play B&O Radio. Maybe this can help in your ‘communication’ with the support ?   MM
Hi Millemsen, thank you for your reply. I sent the same screenshots to the support. Very strange: they sent me the question: do you use tuneIn or b&o radio :-( ... do they know the bo products? the level can only b&o radio.... greetings
Any experience with B&O Radio and how it compares with TuneIn? Initial announcement mentioned that all NL speakers will be upgraded to B&O Radio by Q4/2022. Has this happened?
Beosound core has not been updated...
It's not great. Tunein has way more options.
Tunein had some internet radio stations that I listen to that B&O Radio didn't initially have.  I made a request to B&O to see if they could add them and they did shortly after.
B&O originally promised B&O Radio on the old devices (BS Essence, BS Core, etc.) in 2Q2022, then pushed it out to 4Q2022.  I can't wait for it to happen - TuneIn doesn't have NRK Jazz here in the UK.  I just want to have the same favourites on all my devices - makes it easier to remember what's what. In the meantime I turn on my BS Level then Join on one of my Beolink devices.
There may be some geography-based licensing restriction that preclude Radio in your area.  Dunno.
