With B&O having discontinued its stereo systems, the Beoconnect Core stands as the sole dedicated sound source in their lineup. Given this, you'd think B&O would design the Core to be a versatile product that satisfies customer needs and promotes cross-selling of their speakers and remotes. Unfortunately, it has several major shortcomings:
- No wireless speaker support: The Core only allows cabled connections to speakers, leaving out WISA wireless compatibility.
- Limited to 2.0 audio: It only supports two speakers, with no surround sound option.
- No non-B&O TV control: The Core doesn’t allow you to control a connected non-B&O TV with a B&O remote, even though adding CEC control (already in Beosound Core) would have made this possible.
- Use B&O remotes to fully control non-B&O TVs.
- Very affordable at just GBP 231.
- Potentially a good supplement for those who insist on remote control functionality with their setup.
- No music streaming capability like the Beoconnect Core.
- Requires a wired connection to speakers (no wireless).
- Limited to a 2.0 setup, like the Core.
- Connect Beolab speakers via wired or wireless options, including surround sound setups.
- Basic models: From DKK 1,495 (https://lbs-b-o.dk/produkt/beoone-bt-til-ir/)
- Advanced models (with wireless surround etc.): Up to DKK 10,995 (https://lbs-b-o.dk/produkt/beoone-bt-multi-til-ir-med-surround/)
