Can anyone confirm whether the Home, Back, and up/down/left/right buttons on a Beoremote One can be used for TV navigation through a Beoconnect Core connected to a non-B&O TV, e.g. an LG OLED?
If this is possible, I assume it would cover most everyday navigation needs, especially since I’ve already confirmed that the Beoremote One can control on/off and volume.
Beoconnect Core remote navigation
Sorry I cannot give a definitive answer - only a speculative one.
1. If your OLED panel has sufficient computing power ie that of a C or G Gallery/Evo series, you can’t download the LG B&O control app to the TV.
2. The BC Core and almost any panel I think will have CEC coding embedded in the HDMI port control - so I think that will cover you basic control?.
3. I think overall if you combine BR1 or Halo with a BC Core, the fact it has HDMI, the fact that CEC is almost certainly embedded, the possibility of installing an LG/Bno app, the odds of reasonable control I think is very high
Beoconnect only receives commands, eg:
TV can turn on the connect,
TV can control volume on the connect.
