Beolab 4000 vs Beovox CX 100 - which one is the better solution?
Hi there, the prices for the Beolab 4000 are dropping. It's not a big different anymore between botth speakers on the second hand market. Which one do you prefer and why? Regards Chris
Are you sure about the models you are comparing? The CX100 is a passive speaker and the 4000 is active.
If you compare the specs, the cx100 is going derper in the low frequency range but the maximum sound pressure is higher in the bl4000
