Hello everyone,
I am trying to determine the best setup for my Beolab 50's and multiroom situation. I have been considering swapping out the BS Core that was installed by my dealer for a Beoconnect core. In reflecting on current setup by dealer attached below, I started to question if my current setup is the most ideal to take advantage of my mix of old and new equipment in my living room. Note the rest of the house has newer NL products Level, BS1, Beovision Contour, BS A9, other BS Core and Essence.
Below is my setup
- Beolab 50's current dedicated for music only linked together via DPL and on hardwire network
- Beolab 50's current dedicated for music only and connected to a BS core via power link
- BS Core is hardwired to network
- Beolab 50 also connected to a Roon Nucleus for Tidal streaming and UI discovery it provides connected to hardwire network
- Beosound 9000 connected to the BS Core via line in
- Beogram 4000 (ext RIAA) to BS9000 Aux
- Beogram 6000 (not connected yet)
- In a built in book shelf that fits TV is a Beovision Avant 55 with built in center connected by Powerlink to BL17 Left and Right front surrounds in lower shelf below Avant. Avant is on network wireless due to architecture challenges.
- BL18's via WISA serve as rear speakers to Avant 55
- Beoliving intelligence. Only basic functions are setup so far.
- (3) Beoremote Halos,(2) Beoremote one and one Beo4 remote for BS9000
No subwoofer as I didn't want to add a beolab 19 but couldn't figure how to use WISA for Video and wired for music on the BL50. Seems like you can only go wireless or wired.
Questions I have
- Do I need the BS Core or potential replacement Beoconnect core? I would like to add BS9000 to NL network and just bought a NL/ML converter in hopes I get better control of functions of BS9000
- Do I get a Beoconnect core and use USB C instead of PL from BS Core?
- How do I connect Beogram? NL/ML Converter line in, Beolab 50 line in, Beoconnect Core/BS Core line in?
- To keep Roon in the mix do I consider an external streamer /DAC like a Linn Select and go RCA to BL 50's?
- Can I use my BL50's for subwoofer fill in absence of a BL19 for movies on Avant since architecture prevent hardwire powerlink?
Appreciate experienced suggestions from folks who may have had to manage these decisions.
Login to view image
