Hi there,
I'm wondering if it's possible to connect a set of four Beolab 8000's in such a way where it will work with a Beosound 9000 for listening to music and also with a conventional home theater receiver with pre-amp outputs. Is there a clean way to switch between modes which can be automated?
Beolab 8000 Setup with non-B&O HT system and Beosound 9000
Hi matapan,
I am afraid, the best would be:
- put all Beolab 8000 to the AVR, that could work quite good
- inject Audio out ( from the the powerlink or even via a masterlink cable or device?) to your AVR
- if AVR is built well, it will prevent to power the screen
- all in one integration might be difficult
