beomaster 3500 glass panel broken
Ive caught the B&O bug.
I bought a beomaster 3500 which I now have fully working.. apart from the bottom glass touch screen panel is broken .. due to my leaving it in a bad place and a nosey cat.
Does anyone have one or is there something from another machine that may fit?
Dream audio vision no longer makes them unfortunately.
I am also after a mmc4 or similar for the beogram 3500, that's now working perfectly apart from the stylus that is worn out.
How long does this addiction last ?
Maybe you could buy a non working BM3500 and use that as the donor for your Beomaster?
The addiction is lifelong 😀
I feel you may be right about the addiction.
Yes keeping my eyes open for a bm3500.
