- Do you recommend unmounting the floor stand when moving the TV?
- If I replace the floor stand by the easel stand, do you think it will be easier to move? Do you know if the easel stand is foldable?
Beovision 11-40 transportation
Hi all,
In a few months, I will be moving from Germany to France, and I would like some advice from you on moving my Beovision 11-40 with the motorized floor stand.
Essentially, I have two questions:
Definitely unmount the tv from the stand, when you move it.
I would also do that, even if I just had to move it around inside the house.
The easel stand is very heavy - you can not move it much when mounted.
It is not foldable.
Thanks a lot for your answer!
Do you know the "easiest" way to unmount the floor stand? I saw there are 4 screws behind the tv, I guess we just have to unscrew them.
But how do you hold the tv while you unscrew the stand?
Thanks again
These 4 screws are not ‘holding’ the tv. They are there to secure the tv, when it hangs in the right place/position on the floor stand.
Unscrew and lift the tv upwards with the bottom slightly tilted to the front.
You should never do this alone - it is a 2 person job…..unless you are experienced and/or a very strong person.
My advice would be to have a couple of boxes or alike to place the tv on after lifting it off….let it lean against a wall. This way it will be easier to grab it afterwards, when you want to carry it to the new place. Alternatively put it on a bed, a big sofa or alike…..the screen up!
The tv is heavy!
The stand can be carried by one person - take care when you pick it up.
Ok understood, I will try this.
Thank you very much for your advices!
