Greetings!
My BV11-46 started crackling and smoking and when I opened it up, this is what I found (one or both capacitors probably went bad). Is it better to repair these (and potentially other components) or replace the whole board? What are options (US or Europe/Poland preferrably)? Expected costs? If these went bad, anything else that should be replaced?
Also need a replacement glass...any suggestions?
Thanks!
Gene
BeoVision 11-46 burned component.
Those are the standard mains suppression capacitors that have been fitted to most electronics since the 1970s. They can fail and, when they do there's usually a bang and some smoke, but I would have though this TV was far too young for that.
I wonder if this is tied in with a visit we had a year or two back to change out a board on our Beovision Eclipse TV as a "preventative maintenance precaution" due to a potential failure issue that had been identified? As I'm in the UK, our lovely new forum owners, Multicare, contacted us directly and came and did the job for free, but I wasn't home that day so didn't find out exactly what it was they changed.
As the TV is fairly recent, I would say that your best port of call initially would be a B&O dealer if you have one nearby.
Just replace those two paper foil capacitors. As said, it a common thing.
I've already done some, these were also boards from BV11's. But also some psu's from Essence mk2's and ML/NL converters.
After replacement the powersupplie will work again.
Thank you AdamS and Beobuddy!
