Here's my latest unresolved issue - the usual "Replace 2103 with a new capacitor" trick has failed to get a CD6500 back to reading CDs. I've looked at most of the simpler tests but I've been unable to get it into specification. So before I give up, I thought I'd see if anyone else has any thoughts on a fix that I have not tried.
Some background:
- The 5 voltage inputs on Plug 33 check out OK, both at idle and under operation
- 2103 has been replaced with a Vishay 47uF capacitor. I've also tried a second one and a 33uF Vishay just to see if I could get lucky and have it be a bad capacitor. I have successfully used this exact batch of caps to repair other units.
- No visible cold solder joints on the servo board. The board had two other 220uF caps out of spec which I replaced.
- Laser light is visible, and the arm does pivot easily. The servo adjustment works under certain circumstances - see below
- Passes service mode 1
- In service mode 2 I'm unable to get the laser adjustment to go beyond 18mV- the dial is all the way over clockwise
- In the extreme clockwise setting for laser power, at 18mV, it passes service mode 2 focus test
- Service mode 3 has the CD drive spinning excessively fast - much faster than a similar good unit I have for comparison
- Service mode 4 fails immediately, and continues blinking. This points to a failure of the radial motor servo, from the manual.
