https://forum.beoworld.org/forums/topic/beoplay-v1-connection-old-stuff/ Other old thread suggest that you can also use HDMI to connect the DVD2 to a TV, but you will still need the start connection in order to get control. Not sure how this is setup on the Bsys 4 connection menu. Thanks a lot for the link to the respective thread. I will check with my dealer, if this cable will be still available. If not, maybe Steve can help. From my experience, the DVD 2 needs both connections, HDMI and Scart. The BSys 3 seems to connect them together automatically, if you choose the right connection plugs (in my case HDMI-In 3 and Scart 3). I do not know, if the BSys 4 does put the mini-AV and HDMI „XY“ automatically together, very likely not.Location: Germany
