Hello Beoworlders,
I’m not so lucky on my Beocenter 9000 restoration project, here is the situation for the time being:
I have 2 CD drives :
1 - One CDM 2/10 which was initially in my Beocenter.
It has been recapped by a professional using the CK-003 capacitor kit bought at Beoparts. The 1,5 mF capacitor has not been changed, as stated in the instructions sent in the kit. The original capacitor was a sort of bubble.
BUT unfortunately, while I was doing tests before the exchange, the unit touched the bottom of the Beocenter and a smell occured before I could cut the power.
Here are pictures of the unit:
Login to view image
Login to view image
2 - One CDM 4/24 bought second hand. The seller said that capacitors were replaced.
I had the board audited by the professional who took care of the other drive which did not find broken traces or dry joints
Here are pictures of the unit :
Login to view image
Login to view image
The symptoms are shown in the 3 videos below, made without disc but the behaviour is the same with a CD in place.
https://youtube.com/playlist?list=PL5Sdc5VmHaOKgR8eg2EruXc5HI_-AIlbZ
As an alternative, I have found a classified for a functional Philips CD 150, but the CD is held by a clamp and not by the center as on my drives.
So I wonder what to do without risking a major failure:
- Exchange the servo boards between the CDM 2 and CDM 4?
- Place the servo board of the CD150 on the laser of my units?
- Place the disk holder of one of my drives on the CD150?
OR... send my drives to a Beoworlder who could repair them at my cost?
As I'm not so skilled in electronics, the latter solution would really be great.
But I'm open to any good advice or help.
Thanks by advance,
Yann.
