Dear All .
I have been reading som much these days in order to understand what could be going on.
I have one Beovision 7/40 MK1 upgraded with a DVB Tuner for the HD Channels ( useless again due to new codecs)
Purpose is to use an appleTV connected to the DVI and the audio to the rca.
As of know I have only been able get an HDMI splitter to YPbPr, and this way works, but quality can be much much better if using the DVI.
Issue is that I can't see DVI-I in the HDTV option anther the AV menu.
I have read that this could be due to the fact that the DVB tuner is using this entry internally ( no cables on the outside ), and therefore there DVI is reserved for this, and can't be chosen in the HDTV option as @ravsted
Hi and welcome to Beoworld - hopefully we can help!
Firstly, it should be the CONNECTIONS menu (under OPTIONS) where you tell the TV what is connected, what input to select on Beo4 to use it (DVD, V.MEM etc) and what digital input to use - DVI. Have you followed the procedure in the User Manual, and if so is your User Manual specific to the type of BV7 that you are using, with the DVB module installed?
There are quite a few different SW versions of BV7, so it is difficult to know what might be in both the Service Menu and the normal user menu.
Hi Guy
I must contradict you, I fear.
It is however, a long time ago, but if I recall well:
At some point with the BV7 MK1 B&O used the so-called ‘DVI-solution’ for the HD-tuner…..because it offered a better PQ.
This was indeed ‘internal connected’.
I know of no solution to revert this, apart from opening the tv etc.
@Alcy.
There are plenty of BV7 later MK-versions to get at a very low price…..so why worry with this dinosaur.
Except - of course - you like tingling and solving problems 😉😀
P.S.
There are more knowledgeable people on this subject than me - the only problem will be, if they are present on the forum nowadays.
