I'm helping to extend an existing MasterLink configuration. Currently, it connects only BeoVision TVs (BV7 and BV6). Audio is to be added. The problem is selecting an Audio Master.
Devices to be connected include:
- BeoCenter 2 mk 2
- BeoSound 3200
- BeoMedia 1
- PC2
Logically, either the BC2 or the BS3200 should be the Audio Master. As far as I can see:
- To access music already stored on the BS3200, the BS3200 needs to be the Audio Master.
- To access the DAB radio on the BC2, the BC2 needs to be the Audio Master.
Obviously, there can be only one Audio Master!
So the questions are:
- Have I understood the limitations correctly?
- Are there any other limitations I've not spotted?
- Are there any other reasons to select one Audio Master in preference to the other?
Thank you (in advance) for your help.
Mark
