MCL2P crackles and fades out
Hello everyone, I recently bought a MCL2P from eBay in order to enjoy my Beosystem 2500 through a pair of Beovox 3000 (flat panel) passive speakers. On connecting (with a nice new powerlink cable from Steve @ Sounds Heavenly) the MCL2P would switch on with 2 reassuringly B&O clicks and music would flow. However, after 24 seconds (consistently so) the speakers would make a crackling sound and the music would fade away to nothing. The reset button on the front face has no effect. Only disconnecting from the mains will reset this cycle. And again, only 24 seconds of music before I hear crackle and fade to nothing. On insoection, the main PCB looks to be ok. I have freshened up only a few solder joins which were looking dull. on testing this has had no affect on the issue. Should I take out the power coils and have a look around them too? Has anyone else had similar problems with MCL2P units? I'd love to get this one going. Many thanks, Julian
Beofan for many years with a penchant for 1990s audio systems.
Hi, I have had the pleasure of owning one of these from new!!!! Last time I used it I could not get it to work until I replace one of the fuses inside. I suggest you check them first there are three from my recollecting. Surprisingly, having moved house and come to set it up again,  I came on to the forum to ask the exact same question you raised....why does the sound keep cutting out. I have discovered that it has a feature: "Automatic Power Handling Control which automatically turns down the volume when amplifier has been overloaded" But sadly this is as far as I have progressed. I have tried 2 different sets of speakers with sound input generated from two different phones and a DAB radio but still have the same problem. Ill let you know if I find a solution
