Qobuz compatible Music Streamer for 1st Gen. BeoVision Eclipse...
Hello BeoWorld,
Wondering if there are any recommendations out there for a Music Streamer which is Qobuz compatible and can be connected to a 1st Generation BeoVision Eclipse?
All recommendations and stereo diagram setups welcome!
There should be multiple solutions to this.
If you want an external streamer (to be used with an app on phone/tablet), you could use the line-in/optical on the Eclipse. Just connect the output of the streamer there.
If you want to try that out, go for e.g. a WiiM Mini (these devices have good reputations).
The small box can easily be hidden away. You can even create a seperate Speaker Group for that input….in case you have external speakers connected to the tv.
If the 1st Generation BeoVision Eclipse still supports Casting, you could just (chrome)cast from the Qobuz app on your device.
The Qobuz app should be available for download to the tv (?).
In case this is not supported on the 1st Generation BeoVision Eclipse, you could add a GoogleTV streamer via HDMI…..I am pretty sure you can find the Qobuz app in the Google app store for that.
In case you lean more towards Apple solutions, you could add an AppleTV box - there is a Qobuz app for that.
