Login to view image I had a quick play with the BC2300 last night. It's a Type 2612 SW1.4 version (one-way IR) with the linear (straight line) CD laser movement. Mixed results:Login to view image
- Door opened and closed fine first time - very smooth and small gap between panels when closed. Door motion sensors are working fine - less sensitive than my older 2-way BC2300.
- All keyboard buttons work fine - this was my first ever B&O fix when I fitted a new contact foil back in 2010.
- FM and AM radio work fine - FM presets were still stored from 12 years ago and no problems with FM offset (checked with known stations).
- Display a bit dim - but I have seen how to adjust contrast in a YouTube video, hence may attempt this.
- CD not working!!! It tries to play and then I get the < > (no disc) display. I took the back off and put it in test mode. The CD tests all run smoothly will the laser coming on, trying to focus and full linear movement up/down. Trying to play CD in TESTMODE then gives a Focus Error 2. I'll investigate further but possibly hijack your Ouverture CD thread, as I think it's the same CD module. In the meantime here's a picture with the rear cover removed:
, although I replaced mine with a PL plug, I kept the plug, and just managed to find it in my 'small spares' box. The 'extra' black plastic sleeve is in a fixed position on the remote switch plug: Login to view imageLogin to view image CD still not working - must crack on with that task ...Location: Warwickshire, UK
https://forum.beoworld.org/forums/topic/powerlink-power-up-vs-speaker-on/ mentions pin 1 as powering up and pin 4 as a mute function on older powerlink speakers. Yes I think you are right - I was just working my way through the service manuals to remind myself of the powerlink pins. I also just checked two different PL leads with the multimeter - one was fully wired and the other had all except pin 8 connected. I'll let you know when I check the Passive EDIT: And I just found my 14-year old post on the same subject!Location: Warwickshire, UK
