unable to store speakers role settings
Could you please advise me regarding this situation. I'm trying to add my beolab 8000 speakers as a surround speakers to my beovision 7-40 TV but its turning on/activate the speakers but no sound and not adding it to the TV.
Not knowing which version of the BV7 you have and the configuration overall…..the most obvious reason is, that you can only add surround speakers, if you also have front speakers.
Thanks for your comment, there is front speaker working perfectly.
Which version of the BV7 do you have?
Do you have a centerspeaker also added?
BV MK4 ... Yes centre speaker connected and working perfectly
Sounds like you just have a single speaker connected as a front speaker (center speaker?)
In this case you have to add front speakers left and right first - then you can add surround speakers left and right .
Hope this helps (would help to know more about your setup....)
Stefan
Thanks, I was able store the speakers as left and right front but no sound.
