What are you working on now?
Guy is working on the following
Login to view image
Thanks Keith - my original text follows ...
I thought that I would re-start this thread on the 'new' forum, if only to do a quick test of posting photos ?
I recently got hold of a DVD1, which I presume is the more recent Type 4621. Although there is no B&O label on the back, the rear socket layout matches the manual for the 4621 so that's good enough for me. Anyway, on testing it played very well but occasionally there was a slight resonant (plastic) vibration. I opening it up and noticed a missing screw in the front of the tray mechanism.
Keith has added the photo to the first post (after my photo uploading problems)- you can just see the missing screw hole in the mount nearest the camera. I think it was missing from new, as the mounts internal thread had either stripped or slipped down. I found some slightly longer TX10 M3 x 10mm screws and this tightened fine. No more vibration ?
As a test, I will try to upload a photo of the screws that I purchased.
(No - still didn't work, and I tried both drag/drop and from file manager!)
Finishing off my earlier post with a quick photo of the TX10 M3 screws that I purchased to fix the DVD1 . I got the screws from 'BoltBase' on Amazon - a very quick delivery.
Login to view image
And the picture uploaded fine - thanks Keith! ?
I'm fettling a Beocord 8004 currently. The biggest headache has been trying to work out where the mystery leftover spring sitting on my workbench after the belt change came from! At this rate, I'm going to have to pull the mechanism out of my own 8004 and do a side-by-side comparison.
I'm also trying to acquire two new relays for a Beomaster 8000. RS have had them as "due in stock March 2022" since January, so I've been waiting patiently. They duly appeared, I put my order in and the stock went overnight - now showing "due September 2022".
Luckily I've found them at Digi-Key but had to sneakily order them through work...
Update - I've found where the mystery spring goes. It connects between a peg on the top plate and a metal bracket that is missing!
What the hell sort of trauma has this 8004 been through?!
Hopefully fixing a Beocom 6000. The call answer and 'C' keys were only working intermittently, and then the phone would randomly shut down. I tried a new battery and a handset reset but to no avail.
Anyway, I have just taken the phone to pieces and reversed the little contact strip between the keyboard and PCB (it's a bit like the screen connector in the Beo4) and now it all seems to be working!
Login to view image
Although I have spare BC6000s somewhere I needed to fix this one because it's a Mk1 that has had the upgrade to a Mk2, hence has the right pins to charge correctly on my mk 1 pyramid base PSTN.
Beolit 700 - replacing the dial cord.
Argh - that took a long time and there was a learning curve. First of all finding the right diagram for the cord path - look in the service manual for Beolit 500, because the one found in the service manual for Beolit 700 shows something completely different. After fiddling with the damn string - that I got for free in a Danish fishing equipment store - for literally hours, I figured that I should have a different approach. In the beginning I had tied both ends to the spring which proved to be a huge mistake. New approach: Tie one end to the spring, wind the string four times around the tuner dial knob, wrap it in the correct path and then tie the second end to the string and then snap the spring back down. Job done. Now I just need a few pills for my headache.
I'm refurbishing a pair of Beovox RL 60.2 - one of them had 3 pieces of moulding inside that were broken. They usually hold the screw, so trying to unscrew them would just turn the screw as if the thread was stripped... Fun! Fixed with polyurethane which was what I had available then and I recovered with a new fabric. I have the second one to do now...
I also have a Beomaster 8000 next, but with a hot right heatsink so I'm not in a hurry to get at it. Although I did crack it open to see its state and it doesn't seem too bad overall.
Then a beogram 2000 low on my priorities, since I'll need to purchase a cartridge to test further...
Login to view image
Login to view image
I'm back in the US for a little while so I'm trying to sort out one of my other previous acquisitions, BL Penta MK2. They need the full overhaul so I bought all 3 cap kits and new foam surrounds. These will be the main L/R channels in the master bedroom and the basis of a surround system (eventually!).
Login to view image
I'm an automotive audio and acoustic engineer. I design loudspeakers and full sound systems for new automobiles. I also dabble with studio, consumer and pro audio projects from time to time.
