What is this part?
What is this? And is it a Bang & Olufsen part at all? apprx 65mm long.
Hi Martin, Can you upload mor pictures, of all sides? And add the dimensions? Best, Ernst
It looks the same on the other side. Bottom is plain and black, apprx 20x65mm. Martin
I do not recognitie it as a B&O part, but it might still be one. Looks to me as something that is to be pushed in some kind of frame (with the 4 upstanding feet). And keep two cables/wires apart from each other on both sides. If you have some extra pictures from different angles, my Ai-part finder might help.
Mystery solved. It's not a B&O part. Actually, it was recognized as a foot for a vintage cassette tape carousel.  🤓 Martin
Great! Out curiosity: - Which one? - Picture?
