I have moved a couple of products to different rooms and have renamed them. Everything is recognised under the new names except for the widgets. The product shows correctly however the name under the widget is what is was previously named.
Any ideas how to get the names to show correctly? I’ve tried removing the product from the widget screen but that hasn’t worked. I’m not keen on resetting the device.
Any suggestions welcome
Peter
Widgets - changing names
I came here to ask this same question. I haven't been able to find an answer. I also asked on Reddit. If I hear an answer I'll post here.
I did eventually manage to get the widgets renamed but can’t be sure how I did it.
I think I removed a speaker from the acount and then renamed the other remaining one. I then re-added the speaker that I had removed.
I thing I’ve noticed is that the Theatre doesn’t seem to have a logo as yet.
Peter
