Wiring diagram
You want the Beogram output DIN pins 3 and 5 to go to RCA Left and Right respectively.  Pin 2 is ground. But if you are making your own lead and only have a 5 pin DIN socket you will need to removed DIN pins 6 and 7 (they unscrew). EDIT:  Pin numbers looking into a 7-pin DIN socket (or looking at solder side of DIN plug): I would be tempted to purchase one of these ready made leads from our site sponsor:
Hi VinceV, Incorrectly grounded cables are the most common cause of noise when using turntables.  The cable that I make (linked in Guy's message above) is the same one that I make for B&O to use on the Beogram 4000c and Beosystem 72-23, so you can be certain that this is made to the very best quality and correctly wired. Kind regards, Steve.
He people. is there any way of getting a wiring diagram for my Beocenter 4000? one of my speaker outputs isn’t working and I thought it a good idea to find one. regards Greg
You haven't said whether it's the 1978 or 1985 version, but I just had a quick look in the Products library and the service manuals for both are there. As a Silver Member you will be able to find them here:
Thank you so much 😊 it’s the 1978 version Thank you for the link too, I couldn’t find it. Regards.   Greg
