Hi All,
that BeogramCD showed some strange behaviour, starting off ok but then out of the blue turns itself off incl the Beomaster…….well, that is the interesting point:
does the Beomaster cause the issue and has a problem with the datalink TP1/CD or is it the CD player ??
did a little test and removed Pin 6&7 from the DIN plug of the CD player and reconnected it to the Beomaster…
no sudden shut down and plays through the disc as it should ! The only remaining inconvenience is I can not start or turn off the CD player with the Beolink1000.
i am aware it could be a number of reasons like a uP fault ? With those datalink pins some strange exchange of commands seem to happen.
any ideas, pointers or suggestions ???
kind regards
ALF
